WANTED new gear linkages (Behind gearbox) or very good s/h
nogbad
Hi can anyone help me find some new or v/g used, regards Nogbad
nogbad
BX 16v Ph2 - XPO - x 103
I know the problem very well, there is even video evidence on YouTube. Personally i'm going to go down the route of rose joints and then i will never have the problem again.
I believe as a temporary fix there is a way to use a zip tie (cable wrap) to hold the linkage down and stop it sliding off. I've seen it a few times, and one owner i spoke to said he'd had it like that for some 20,000miles withought a problem.
'I believe as a temporary fix there is a way to use a zip tie (cable wrap) to hold the linkage down and stop it sliding off. I've seen it a few times, and one owner i spoke to said he'd had it like that for some 20,000miles withought a problem'
AH HA! the famous temporary permanent repair!
