Computer wiring
x 103
The 'door open' switch is located physically inside the door lock motor.
Your problem will likely be a break in the wiring between the door and the car.
scrappydoo
Post by scrappydoo »
Vanny wrote:The 'door open' switch is located physically inside the door lock motor.
Whereabouts is it positioned? Also shouldn't the bonnet show up when open on the display also?
x 103
Where abouts is the door lock motor positioned? In the door, near the lock, connected to the lock by a short metal rod.
scrappydoo
And I take it the bonnet should show up on the display as there is a wire going to the display for it according to the wiring diagram explanation that was kindly given.
prm
Post by prm »
With the bonnet open display, you need to work through the circuit.
First check the bulb, a 9v battery, with short leads helps. Remove the switch, check to see if this operates, open and closed. Then check continuity of the cable - bonnet to display unit, pin 7. You should? have a circuit. On the rear of the display unit where the bulb holder locates, check to verify connection with the two half-moon copper contacts. One section should be + supply, the opposing section should be too pin 7,
and confirm the bulb holder contacts are making a connection when installed into the display unit.
The above operation applies to all the other display operating circuits.
Regards
rayfenwick
Post by rayfenwick »
Vanny wrote:A very quick Google brings you to this website;
http://citroen.podolsk.ru/bx/docum/haynes/
ignore that the text on the screen is not in english, the links are. The top link is to the electrical diagrams in the Haynes manual.
I used to live near Podolsk...
Ray
www.citroencarclub.co.uk
