Hi technical folks,
Im very definitly considering a BX14 with the 150 slant back engine.
It doesnt need these things now but for future reference should i actually get it.
Do you have to remove the whole engine/box lump to change the clutch on these? I remember you did on the visa equipped with these engine, but maybe there is more room in the BX?
With the 14's the hydraulics only run suspension and braking right? so no FDV's or Rams to worry about, does this mean they also dont have an octopus and are basically more simple in terms of hydraulics? (in fact more akin to a GSA which im familiar with)
Thanks all, and hi Stephen if you are reading this
BX14 Clutch quesion
- Stinkwheel
BX14 Clutch quesion
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- ken newbold
The car will have an Octopus as the suspension and braking system are as all other BX's, it will also have an FDV but with less outlets as the 14's dont have PAS and don't really need it.
As for the clutch, I have never done one on one of these early 14s but a mate of mine did, and I'd like to point out that he had no mechanical experiance at all other than changing oil & filters, and he did his clutch in an afternoon. So no, you don't need to remove the engine and I suspect it's a lot simpler than the later 14s where the gearbox has to come out.
- Stinkwheel
thanks ken,
its been a long time since i did any 'serious' work on a BX
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- ken newbold
- Stinkwheel
excellent, apart from the pump design exactly the same setup as a GSA then with accumulator sitting on the regulator.
watch this space
watch this space
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
