where i put the turrometre on board
alexromania
Yahoo Messenger: alexutzu_yod
Post by alexromania »
helo, somebody knouws where i put the turometre on board , on a bx serie 1 1.9 diesel, with leds turometre, that band who mesure the rotatins
bx serie 1
alexromania
please a picture or a electrical scheme
bx serie 1
Ok, erm, I *think* you mean the sensor for the Rev counter?
In which case it's down the back of the engine and sticks through the rear plate facing the flywheel.
Some early ones had the sensor located in the top of the bell housing (like the petrol CAS)..
Unless you mean something quite different!
alexromania
sorry i don't know very whelle english. I whant to mean where i put on dashboard, a picture with the scheme electric
bx serie 1
alexromania
i have the sensor on top of the engine, but where i put it on dashboard
bx serie 1
Ahh, I'm with you, no problem mate, your English is infinitely better than my Romanian!
What year is the car? Is it a Mk1, or a Mk2?
I assume Mk1, in which case I believe the rev counter was a strip light at the bottom of the instrument binnacle?
alexromania
bx serie 1
alexromania
bx serie 1
alexromania
nobody can"t help me?? :? :( :(
bx serie 1
Hello Alex,
I'm sure someone can help you - I have the same car as you. Can you post your question in Romanian and then it might be easier to understand?
One of our members - TB2 - can speak Romanian and English and can hopefully translate your question correctly.
alexromania
oo yes i can do that.
problema mea este in felul urmator, eu am un bord cu turometru cu leduri, am senzorul pe cutia de viteze, si am si o mufa pe bord. problema este ca nu stiu unde se pune in bord, in ce pini din bord.
bx serie 1
Simon B
Post by Simon B »
Google Translate does a good job of that. It looks like he wants to know how to wire up a Phase 1 LED rev counter.
Have
1971 Dyane - This IS the ONE :D
2006 C5 Exclusive V6
Had
Xantia, BX19 GTI, Dyane, BX14RE, AX, 2 x Visa 652, Dyane
alexromania
up is a picture who show how look is the dashboard for boughts side's. in back of dashboard where i connect the wires, i whant to know where i put the wiers,
bx serie 1
Ok, so it is understood already - we don't need TB2 to translate! :D
I would have to remove my dash and take a photo to be able to give you an answer Alex. I will try this weekend.
alexromania
THANKS MAN, THIS WEEKEND IS THE EASTER IN ROMANIA, AND I'M NOT GONA BE IN THE FRONT OF MY COMPUTER BUT I'LL RECEIVE THE MESSAGE, THANKS FOR YOU TIME.HERE IN ROMANIA DON'T FIND THIS PEOPLE WHO ANSWER IN THIS SHORT TIME LIKE YOU DID.THANKS AGAIN. IF YOU WHANT TO SPEAK ANOTHER TIME I GIVE YOU MY EMAIL ADRESS ALEXUTZU_YOD@YAHOO.COM, AND MY MESSENGER ADRESS ALEXUTZU[/b]
bx serie 1
