diesel fuel pipes
Dennis Rosser
diesel fuel pipes
Hi, is it possible to buy new diesel fuel pipes for my bx estate ? Mine are rusting away. Thanks.
cauchoiskev
kermit the frog
I would tend to go for copper pipe as a replacement and the correct diameter pipe can be obtained from a commercial vehicle brake supplier.
Also you will find it much easier to fit as it is easy to shape.
It will also outlast the OE pipe.
You should require about 3 mtr's/10ft this will be more than enough.
Regards Kermit
Regards Kermit
kermit the frog
