FS BX electrical gubbins UPDATED
x 103
I'm about to have a rather large throw out of BX electrical bits, i'm rapidly loosing favour with storage facility (dads' garage!). This is a typical example of what i'm talking about, though there is more than this;
Box1
Box2
electrokid
Post by electrokid »
Hi Vanny,
I'd be interested in the multi-switch (white circle) and possibly the green circled foglamp switch. I'd like to fill the little switch panel on the right hand side of the steering column -the one that is low down at about the same level as the dash lighting contol - do these switches and any others you have fit that little oblong panel ?
Cheers,
Brian.
Yes, they will do. There is still space for another switch (a man can never have enough switches!) which on mine has the light for the trailer indicator flasher bulb.
I'd be interested in some of your relays please Vanny, I'm after 4 standard and one changeover (5 pin) for a little project I have on the go...
electrokid
My thoughts entirely :-) Thanks for confirming for me that these are the right switches for the little panel.
I recognise the problem :-) Long time back I had the chance of some electronics kit at a very good price but nowhere to put it so I asked dad if there was any space in his workshop. "Tell you what" he said, "I do have some space spare to store MY wheelbarrow" :-) which I took as a subtle hint that I should perhaps return it :-)
And on the same theme... working for the MOD in the late 60s, a workmate came up to me and said "Do you know the difference between 'recall' and 'recollect' ? " I had no reply and asked for clarification. "Well" he said, "I recall lending you my sidecutters but I don't recollect you returning them" :-)
electrokid
Vanny - PM sent.
x 103
electrokid, you have return PM, sorry for the delay
Matf, can you let me know your address (again) and i'll post them over to you.
lateestate
Post by lateestate »
Would you happen to have a spare hazard warning switch ?
x 103
I do have a few, i haven't pictured them as i know one of them is broken/failed but i have no way to check it. I think i have a grey one, a brown one and a black one. What colour do you need?
electrokid
Hi Vanny,
Something very strange is going on with private messages...
Your original message didn't get through - no worries
Your second one did :-)
I replied last night to that one
This morning I checked my outbox - last night's message not there
Sent new reply this morning
Immediately check my outbox to confirm it was sent
Opened the sent message - It contained the text from last night's message ! !
The date and time sent were correct for this morning but the text was the message I sent last night !
So... whoever is sorting that lot out - the very best of luck :-)
PS I also sent you a message to explain as above - but that didn't appear in the outbox hence posting here instead.
electrokid wrote:So... whoever is sorting that lot out - the very best of luck :-)
I don't have a clue, all this electrickery and computing is all done by smoke and magic anyway! You should have a PM from me too Mr Vanny, it's sat in my outbox now.
x 103
I've PM'd you about what happened, its simply a trick of the light, i received both messages just fine, its an important difference between the 'SentBox' and the 'OutBox' in the PM system!
lateestate
Vanny wrote:I do have a few, i haven't pictured them as i know one of them is broken/failed but i have no way to check it. I think i have a grey one, a brown one and a black one. What colour do you need?
Black please
jacksun1987
Post by jacksun1987 »
have you got any centrol locking things.
My centrol locking dosent work. And i not have a key fob. The bloke at the gaurge sad. Get another one from another bx. Then swap it other with the code.
Thanks
PAUL JACKSON
cosa 1.2 brezze 150 k had
x 103
lateestate, i have two in black, one is definately broke, the other is a total unknown. If you can wait till next week then i'll check them?
Jacksun, I think your asking about the plip receiver that lives in the roof. I think i have a receiver, but i don't have the matching plip, so i dont think this is of any use to you. There are instructions online on how to convert to an RF plip from Maplins. This would give you greater range, greater reliability and you wouldn't need a matching pair (you program the plip to the car). Try searching within the forum.
x 103
I've updated with a second box, i'll try to delete out parts people have snaffled over the weekend.
