Hi all
Has anyone changed a battery tray on here? Wandering if these are still available from Citroen? It's an '88 16V. It appears there's been a leak of battery acid at some point in the past, and it's now looking less than pretty under the bonnet!
I know they need welding in, so this isn't exactly a simple job, but any info from anyone that's done it gratefully received!
My dad's getting a pic of it over the weekend, so will post up when I have it
Adrian
Battery tray replacement?
Adrian E
BX 16v Ph2 - XPO - x 103
I'd say it was a pretty simple job, depending on how you do it. The construction is two outrigger from the wheel arch/chassis leg and a shelf on top. If you where to cut the 'shelf' bit off you could VERY easily fashion up another one with little more than a grinder and a hammer. They don't need to be too precise.
I've never seen one for sale on eBlag, which suggests you stand half a chance of buying one from Citroen as they are likely to be rarely sold. I'm sure Citronut will get you the price/part number.
If you can't get a genuine one, then you might be able to get one from another model, or even another make, and shape it to fit. I think Xantia's have them in a similar position.
Alternatively, could you not just patch the one you have?
Adrian E
Adrian E
Hiya
Right, pics. It's clearly suffered some acid corrosion at some point in the past. Looks to have eaten the paint underneath the battery tray as well.
Suspect you're right Vanny that a replacement top part shouldn't be that tricky to do. Looks like the area will need to be treated and painted though.....
Yes I agree with vanny, it just needs a localised repair and then thouroughly treating / sealing and paint.
