I had to do a cv boot yesterday on the BX and broke the holding circlip.
There wasn't a circlip in the kit I got and had to fabricate one which I am not very happy about.
So ! where will I get some from please ?
Drive shaft circlips
Discoil
Land Rover Discovery TD5
Re: Drive shaft circlips
The main dealer is the best place, only a few pence each and there O/E !Discoil wrote:I had to do a cv boot yesterday on the BX and broke the holding circlip.
Also discussed recently in THIS thread under the technical section, had you not spotted it (or used the search facility) ?
Discoil
I have tried a main dealer and they are not available separately , and used the part no. shown in the technical section which I found later on, after I had posted.RxBX wrote: The main dealer is the best place, only a few pence each and there O/E !
Also discussed recently in THIS thread under the technical section, had you not spotted it (or used the search facility) ?.
I had replied to a previous posting then found that I could not delete the post and so that is why,sorry, that mine is there.
scrappydoo
