LHM everywhere - mini-octopus
Oh well. It's been a while. Looks like a high pressure return line has failed near the reservoir - LHM all over the place. It's the small one that comes from the bulkhead and joins the 'big fat one which goes to the accumulator. There's a bit of copper pipe in there, so I presume it's failed before - in which case, I don't know why it's now peeing out everywhere! Tried fitting it all back together again but as soon as you try forcing a return (ie dropping the suspension) fluid sprays everywhere.
Any thoughts? Is it easy enough to change the faulty pipe? And where's the best (ie cheapest) place to get LHM? I've used up my emergency bottle...
Stinkwheel
Post by Stinkwheel »
Hmmm got a pic of the area in question Ian? I cant picture it.
if its a 3.5mm pipe then ive got the flaring tool etc to make you a new one. If its that type, im unsure till i see it.
as for LHM. I buy the 5 litre big fellas from my local wilco car master. 21 quid ish.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
kiwi
Post by kiwi »
If its the pipe I think it is then it is not a hard job to do.
I am assuming you mean the pipe that goes from the pump to the accumulator? The pipes to the reserviour are generally low pressure?
kiwi wrote:If its the pipe I think it is then it is not a hard job to do.
Hmmm. If that's low pressure, that's some spray! S'pose it's less than 200psi or whatever it runs at...(lost enough fluid for the warning light to come on within about 100 metres of driving). I'll get some pics tomorrow.
Stinkwheel
If its emptied that quick, its hige pressure, as i understand it all return lines are low pressure, although i may be wrong, so i definitely need to see thos epics 'yan :)
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Of course, could have been that it leaked all the way to the office, and gawd knows how long before...
Right, here's the pic.
The arrow shows (well, underneath that big pipe) where the LHM is coming from. There's two small return pipes joining the bigger pipe. Neither connection looks clever. The main pipe then runs down to the accumulator.
From the front of the engine, it all looks nice and easy to replace the pipe. However, I can't see where the two small pipes run off to - are they really part of the same pipe? Could be fun...
JayW
x 13
Post by JayW »
I believe that's the return pipe from the Steering Rack & FDV at the far end. The 2 small returns could be from the rear suspension???
I've just removed part of it from my valver as i've changed to manual rack.
Gibbo2286
Post by Gibbo2286 »
This any help?
Thanks but that doesn't seem to be helping. Can't spot what hose I'm after amongst that lot.
Aerodynamica
Post by Aerodynamica »
I think it might be the return(s) from the front and(or) rear corrector valves (No.1 on the second diagram)
Only thing I can think is to have an assistant make hydraulic bits move in succession and observe which one causes it to piss?
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
Aerodynamica wrote:I think it might be the return(s) from the front and(or) rear corrector valves (No.1 on the second diagram)
Ah, that could well be it. So are the small pipes part of the bigger pipe? There's so much copper-pipe-bodgery that I'm not sure what it's actually meant to look like. One or both of those small pipes are clearly leaking where they join the big pipe.
Gibbo2286
Post by Gibbo2286 »
I think the one you've marked in red is number 1 in my lower drawing, it goes from the regulator back to the reservoir, it has two thinner offshoots that come from the height correctors (via the octopus) and join into it (behind your arrow) and if you have power steering I think there's also a connection near the regulator to the directional valve.
Could be it - certainly, as soon as you drop the ride height, LHM comes out with some force. So, do I need to replace the main big pipe or can the small ones be replaced/bodged?
x 116
Its always best to replace with new where these hoses are concerned. especially as its been bodged before. They get brittle with age and with diesel around.
This hose is known as the mini octopus- 95 603 420 It handles the returns from both height correctors via the 2 side branches and from the flow distributor and the power steering via the fatter tube.
If you have a post RP 5167 model with 3 instead of 2 side branches then the routing and functions are a bit different.
