AX, GS, Visa and misc. unidentified bits for sale - NOS
KevR
- x 4
Lots of odd stuff from the stock of a former Citroen dealer.
Some is a complete mystery, some has part numbers but I can't find the references. Hoping that some of them will make sense to people and get some of this stuff off my shelves and into the hands of people who've got a use for it.
Offers and extra info welcomed on the following:
5RB 7920 062790 washer reservoir
95 575 617 rubber door trim? GSA?
95 612 099 plastic vent?
??? rocker arms x 3 (GS?)
???? coil AC Delco on aluminium base/ heatsink. CX?
95 632 636 oil cap (AX?)
7901593723 paris rhone rotor arm (also marked 40211913)
CA 5456 FRAM air filter. ZX 1.9D
??? Air filter Visa 2 cyl x 9 (also fits audi and vw)
??? AK350/AK400/Dyane 4 front brake shoes (several sets)
95 619 515 AX rear brake shoes
95 619 515 Visa diesel rr shoes
755 215 559 Visa/LN rr shoes (1 missing?)
??? Visa(?) disc x 1
??? Small discs x 4. Really little! 4-bolt. Must be rears for something.
?? GS/GSA handbrake pads x 5
?? CX handbrake pads x 1
95588 903 brake pads set of 4.
3G H 5448 795 needle roller bearings and fittings. 2 x boxed pairs.
ZC 9620 054U wheel bearings? x 4
95 572 590 flanged bearings. Gearbox? x 2
5 485 486 heater cable of some sort
7 910 033 436 handbrake cable. orange casing.
95 493 551 identical to above
AM 521282a speedo cable
96027 855 speedo cable (upper?)
95 634 825 Choke cable. AX.
?? Rear exhaust box. Marked AX 1.4
?? rear exhaust box, same mountings as above but slightly smaller.
??? RIght rear wing/quarter panel. GS (maybe GSA)
I could be interested in the GS rear wing - is it for a saloon or estate?
All the best,
All the best,
KevR
- x 4
Saloon I think. I'll have a look later - have a feeling it's got a part number on it somewhere.citsncycles wrote:I could be interested in the GS rear wing - is it for a saloon or estate?
sjeffs2
Re: AX, GS, Visa and misc. unidentified bits for sale - NOS
Can I have these please?
Stinkwheel
Kev,
Is the right reat GS or possibly GSA quarter panel; thing still available please? ( i know this is an old thread)
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
KevR
- x 4
I'll have to see if I've still got them - it was a long time ago!sjeffs2 wrote:ZC 9620 054U wheel bearings? x 4
KevR
- x 4
Right then....
Yes I've still got the bearings. All new old stock. Three in cellophane in VGC, one in Citroen box with some surfave rust on the outside of the race and the grease has gone hard so will need flushing out and regreasing. Make me an offer - can post in UK beginning of next week or leave for collection near Loughborough.
Also still got the GS/A panel - 99% certain it's for an estate. Part number 7GX 5483 204 if that helps, or can email a photo. Again, can leave for collection at Loughborough or possibly near Swindon.
If it's for an estate, I believe it can be made to fit a GS saloon fairly easily, but the trailing edge of the wing for a GSA hatchback is a different shape and I believe slightly longer.
Stinkwheel
Hmmm wouldn't mind a pic if its not too much hassle, fank yooo!!!
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
WESTON89
I've had a few Gs so may be able to help identify which wing it is with a photo.
1951 U23 Tipper
1975 CX 2000
1987 CX 25 GTi Turbo 2
1988 CX 25 GTi Turbo 2
1989 CX 25 GTi Turbo 2
1997 Xantia V6
1975 CX 2000
1997 Xantia V6
KevR
- x 4
Hopefully, here you go. Spot the bearings in question as well....Stinkwheel wrote:Hmmm wouldn't mind a pic if its not too much hassle, fank yooo!!!
Stinkwheel
Im fairly sure that is estate, in which case i will pass in afraid.
should be gold dust to someone though
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Yep, estate wing, although if you have a GS saloon you can cut off the pillar and graft it in.
Stinkwheel
Unfortunately (or fortunately) Ive a GSA saloon. My GSA estate went south due to extreme rust about 5 years ago now.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
yep defiantly estate which means it will fit both GS and GSA,
pm sent
pm sent
