Wiring - connector without a home..
Eric Brough
My Cars: BX 16TXi
C5 Mk1 Facelift 2.0 HDi estate
C6 2.2 HDi Lignage
Fiat 500 Lounge
Post by Eric Brough »
Hi on my BX 16TXi theres always been a little mystery. Theres a loom that runs across the front of the engine which has wires going to the starter soleniod, the alterator and the block coolant temperature sensor. At the point where the wire to the starter solenoid emerges, there is also one of similar length with a blue female spade connector on the end. This has always hung loose, unattached. Anyone know where it should go or what its for ? Thx, Eric
BX 16TXi
C6 2.2 HDi Lignage
Fiat 500 Lounge
I have a brown wire coming out of there and where on a diesel it goes to the diesel stop solenoid but it doesn't have a blue female plug. Is the plug an aftermarket crimp type where a previous owner has used this wire as an ignition feed for accessories, spot lamps or similar?
Eric Brough
My Cars: BX 16TXi
C6 2.2 HDi Lignage
Fiat 500 Lounge
Looks like a regular original rectangular-plastic-sleeved connector and part of the original loom. Maybe its the same loom as for the carburettor BX16s and it went to something on the carburettor ? enrichment device ? E.
BX 16TXi
C6 2.2 HDi Lignage
Fiat 500 Lounge
Mike E (uk)
Post by Mike E (uk) »
In a similar vein,on petrol EFI BXs, what is the unused brown female spade connector on the short green wire by the ignition coil intended for?
Mike
Gibbo2286
Post by Gibbo2286 »
Browns are all ground/earth wires. I'll try to look up the blue in the first post later on. Gibbo.
Oscar
Re: Wiring - connector without a home..
Post by Oscar »
Eric Brough wrote:Hi on my BX 16TXi theres always been a little mystery. Theres a loom that runs across the front of the engine which has wires going to the starter soleniod, the alterator and the block coolant temperature sensor. At the point where the wire to the starter solenoid emerges, there is also one of similar length with a blue female spade connector on the end. This has always hung loose, unattached. Anyone know where it should go or what its for ? Thx, Eric
Are your reversing lights working?
Eric Brough
My Cars: BX 16TXi
C6 2.2 HDi Lignage
Fiat 500 Lounge
My reversing lights are just fine...
E
BX 16TXi
C6 2.2 HDi Lignage
Fiat 500 Lounge
Eric Brough
My Cars: BX 16TXi
C6 2.2 HDi Lignage
Fiat 500 Lounge
Mike E - assume your question about the unused wire near the ignition coil relates to the BX19i models. I dont have a loose wire in that vicinity on my BX16i. E
BX 16TXi
C6 2.2 HDi Lignage
Fiat 500 Lounge
