''Peugeot 3rd & 4th gear best mod you can have'' ??
- Keeper of the site Goat
- x 94
KevR
- x 4
A lot of road rally drivers using Peugeots have close ratio boxes for 1/2/3/4, then the longest they can get for fifth, so they can keep wear and tear (and noise) down on transfer sections. I've often wondered about sticking a taller fifth in the BX for motorways.
KevR
- x 4
No idea! The attraction of the fifth gear mod is you don't even need to take the gearbox out - it's done via the steel cover on the end.
yes, but it's a bit of a faff, and the overall gearing is no real improvement.Roverman wrote:Can you fit the 6 speeder out of a GTi-6?
Much easier to swop the 5th gear set.
Mike P
As the Doc said above, it is possible but note that the end of the box would clash when full lock was on, as you also get when fitted to a Mi16 converted Peugeot 205.
Mike E has a longer 5th gear on his 16V, from a diesel.
Having taken the car in the ebay add for a test drive very early this year when the previous owner in Sheffield was selling the car, it is a quick one but a bit rough and rotten underneath. Would be a good project car but wants some time and money spending on it.
Mike P
Mike P
