Can anyone tell me what the 4 connector pins should lbe wired to? The brown is ground. One is 12V continuous, one is sidelights - that leaves one other ... and I don't know which pin is which. The Haynes is useless, it actually shows 5 pins on the clock in one of the diagrams. Archives don't help either.
Steve
digital clock connector pin id
sdelasal
If you have a multimeter you can check which are which - there should be about 120 ohms between ground and the ignition feed (which will change to infinate resistance when the bulb is removed). There will be a higher resistance than this between ground and the sidelight supply, again changing to infinate when the bulb is removed. The other terminal will be the permanent 12V feed, the resistance between this and ground will not be changed by removing the bulb.
sdelasal
electrokid
Another way is to test for volts rather than ohms...
Get a meter or test bulb and connect one side to a part of the car's bodywork.
Switch on ignition and sidelights.
Probe all 4 connections with the other end of the test bulb or meter.
The connection that doesn't read 12v or cause the test bulb to light is ground / 0v.
Switch off the sidelights and re-check - the connection that was 12v before and is now dead is the sidelight connection.
Switch off the ignition and re-check - the connection that has just gone from 12v to zero is the ignition.
And the one that is still 12v is the permanent 12v from the battery (and is routed via fuse 8 according to the drawing).
Hope that helps.
Hope that helps.
electrokid
sdelasal
electrokid
