The situation!
BX19TZS 1991 v BX19TRS 1990 both have the same tyre brand and depth size etc except one has an odometer/speedometer the wrong side of accurate. ie TZS shows 106kph and TRS shows 97kph when the GPS reads 100kph! This flows through to the odometer obviously.
Now you would think that two BXs of the same specs just differant trim levels would then read the same on the REV counter in 5th at 100kph on the GPS...yes???
Nope! The 19TRS Revs at 3200 at GPS 100kph the 19TZS reads 3100rpm ok not to much a differance.
But when the 19TZS is doing its indicated speed of 100kph true 106kph the revs sit at 3200rpm where as the 19TRS indicates 110kph to read 106kph GPS and the revs are 3400rpm.
Hope you guys understood that?
So by using this method of establishing true speed with indicted and revs would the differance of 200rpm@106kph and 100rpm@100kph point towards a differance in gear ratios at the gearbox?
This 19TZS is a mystery car having sat 2 years in storage before being registered on NZ roads. Yes both cars are whats called NZ new meaning they were never driven overseas. If only cars could talk!
