Hunting GTI
Hunting GTI
Collected my new project yesterday, she was taken off the road in 2007 with a running problem thought to be a fuel pump. It does start and run, BUT smells of petrol and seems to keep trying to stall then suddenly comes back to life again, when you rev the engine the throttle seems to stick slightly before it returns to normal tick over.
The fuel pump itself is quite noisy and you can hear it running.
Thanks! :D
sdelasal
Post by sdelasal »
Try... disconnect cable & check that throttle moves freely and returns to end stop okay.
There should be a switch indicating throttle is closed - check this clicks when it should and check its okay electrically. If this is broken it can cause funnies as the engine controller does not know when to do idle speed control.
Check all the vacuum lines and rubber hoses between the idle valve, the intake manifold and any rocker breather tubes - any leaks here generally mess up idle performance.
Steve
Thanks Steve, will do, will also give it a good clean with injector cleaner when it warms up.
Post by citronut »
maybe you require one of these ebay item No. 280594145811
already seen it and on my watch list thanks!
I don't think it is anything to do with an idle valve, more likely to be the second butterfly that is not able to operate smoothly and close under it's independent spring pressure. This is probably due to light corrosion on the shaft in the throttle body. Clean it, lubricate it and work it and I'm sure you'll see an improvement.
