Part Number required
kiwi
Post by kiwi »
Any ideas on the part number for the Return pipe that goes to the Front and rear Height corrector and main accumulator/FDV from the reservior?
Seems my local ^^ ^^ agent has no idea. :roll:
The one from the rear height corrector to 'oil back harness' ( Octopus) is
79 05 026 874 for all models
Then there are two smaller pipes ( neither of which are available) that connect with the octopus from the regulator. Which one do you need exactly?
kiwi
Post by kiwi »
The big one that starts in the reservoir goes down to a t-piece (well it is on on the TZS) that serves the Regulator and FDV. It has two smaller pipes branching off from near the reservoir that go down to the HCs.
Make it easier its the other one of the pipes on the clip attached to the Alternator bracket that does not go to the Pump.
See photo
Post by RxBX »
Hi Kiwi,
With a picture, that makes it much easier to decipher which return pipe/s your referring to !
Up to RP Number 5167, the part number is :- 95 603 421 (Oil Back Harness)
and
From RP Number 5168, the part number is :- 96 119 048 (Oil Back Harness)
kiwi
Post by kiwi »
Thank you and thanks for the PM
kiwi
Post by kiwi »
I got a price for that pipe today from the main dealer and I wish I was sitting down!!!!!!!
$246.80 as in over one hundred quid :shock: :shock: :shock: :shock:
Ok the bodge and fix has now become the permanant solution until it breaks again.
How much would it cost to post one out to you from Blighty, surely thats got to be a cheaper option than buying local?
kiwi
Post by kiwi »
Depends how much one is in blighty?
I dont have to pay VAT if i order it direct which should balance out the cost of the postage I hope.
Post by citronut »
here is UK price and part No.'s for both type's/RP No.,
95603421 OIL BACK HARNES 64.20 GBP 77.04 GBP 77.04 GBP
96119048 OIL BACK HARNES 57.15 GBP 68.58 GBP 68.58 GBP
this is including UK VAT,
