All I can find on the forum is a reference by 'Doc' that its one of the easiest cars to do!!
Indeed it is. With the engine running and with a suitable size of wood jammed between the seat and brake pedal (so the brakes are fully applied), proceed to loosen the brake nipple until the air is removed, if you want to save the LHM just attach a short length of plastic hose and drain it into a suitable container.
Note!: Before trying this make sure you can easily undo and retighten the nipple before starting (imagine if you sheared off the brake nipple with the brakes applied). As the hydraulic pressure in the braking system is significant, so be careful to just crack the bleed nipple, and keep the spanner on it, so you can nip it back up in an instant.
This is one of the few cars that you can quickly and easily bleed the braking system on your own.
To bleed the back brakes is a little bit more involved, but the same principle applies.
