some nasty person has dented my front wing. looks like the only way to fix it will be to push out from the inside.
so i'm gonna take the wing off. haynes says it's just a two spanner job - anything to look out for that could trip me up?
ta and happy bx-ing.
rob
wing removal
RobC
- x 30
wing removal
RobC
- x 30
Mike P
On a 16V, the bodykit piece at the front of the sill has a tab on it that is screwed to the front outer wing, which is then hidden away behind the arch extension bodykit section bonded to the wing.
I'm yet to work out to access this before you take the wing off and snap this small bit of GRP apart
Mike P
Mike P
