What petrol do i put in a 1989 bx 16v
james cartledge
I konow this may sound silly but its been around 8 years since i owned a bx 16v and i used to run my 16v,s on lrp which was a red petrol pump back then
i,m due to pick a 1989f plate 16v this week and id like to know if i can run it on unleaded or if i have to find a petrol station that still has lrp available
im sure you guys will know the answer
cheers
james
cheers
james
- x 27
Pretty sure that standard 95 unleaded is fine on all bx petrols inc mk1's, unless anyone knows different?
johnbird
the 98 ron would be a waste of money if the car is mapped to 95 ron.
the roadster will run fine on 95 ron but is mapped to run on 98 so it is improved when run on 98. a non turbo motor may run a little cooler i suppose but i dont think you will see any performance gains. i may be wrong though..........
audi a8 quattro
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
saab9-5 aero
saab99 turbo
smart roadster
citroen bx tzd
kiwi
- x 4
If memory serves me correctly the BX 16 Valve has a differant engine manufacturer to the Pug engines fitted to the BX 16 and 19.
The BX 16 and 19 are designed to run on minimum 95 octane unleaded even the phase 1 the exception being the 14 pre 1988.
From memory the BX16valve should run on no lower than 97 Octane although the BXs I have seen in NZ were running on 95 octane prior to the arrival of 98 in 2003.
I can not say for certain but if memory serves me all cars built in europe after 1988 were designed to be able to run on unleaded, Rovers were one of the last car manufacturers to build cars not capable of running unleaded fuels.
Pretty sure that someone who owns a 16valve here will be able to give you a better answer than us none 16valve BX owners can.
The only thing i noticed running my 8valve gti occasionally on the higher octane fuel was that it ran a bit queiter & seemed slightly smoother & that was about it. It may very well have a slight performance advantage, but we are talking about a 10th or 2 at the most, so basically its a waste of time. Might be worth using a tankful before an mot is due & doing an italian tuneup, but not worth the money imho. Never had a car optomised for higher octane fuel, so can't comment on that.
kiwi
- x 4
RobC
- x 30
if it's a bx16v 1989 model it will have the motronic ML4.1 system, which doesn't include a 'knock sensor' to adjust the timing to suit different grades of fuel. this feature came in with motronic M1.3 in 1991.
therefore it will definitely run more smoothly on higher octane stuff but you won't damage it by running it on 95 (and you'll lose a bit of performance).
Super plus only.
D6C's were designed to run on leaded 4 star only.
Until the catted DFW arrived.
Yes, you can run them on 95 unleaded, but you'll loose some performance, and if you rag it often you'll burn the valves and seats out.
V-Power 99RON or Tesco 99RON is ok, certainly I've had no issues with either, and thats the only fuels I've used in my valver since I built the engine.
The head that came off it when I bought the car had serious pitting on the inlets and all the exhausts were burnt out, and it had been run on 95 for years.
kiwi
- x 4
Matt H
I use either V-Power or Tesco 99 wherever possible, but I have used lower grades on the odd occasion. Not a problem every now and again, or if you are skint ect... but just stick to the good stuff where possible, and you won't have any problems. If I'd spent a lot of money on an engine rebuild, then I would probably religiously use 99 too!
I've still got a white Phase 1 as well. We need to start our own club...
Matt H
- x 94
