Front strut weight
- maxgreenwood
Front strut weight
How heavy are BX front struts without the sphere?
You can probably guess where i'm going with this..
namely across the Irish sea
'90 16TZS (m), White, 86k
If you hired an olympic hammer thrower, I reckon it would make it...
Martin
- maxgreenwood
I'm only guessing, but about 5kg each?
- maxgreenwood
they're bl dy heavy i found after lumping them about moving house. i'd say more like 10kg each at least?
- x 20
- maxgreenwood
well don't go out of your way, if you happen to be in the same place as a strut and scales at the same time...
- x 20
Surprisingly light actually - 3.6kg! I checked on 2 different scales as I didn't believe it, I must be getting weak. This is without the sphere or top mount, just the bare strut.
How do you want to claim your prize Mulley?
If you needed one desperately to get you out of trouble I'd be prepared to loan you one, but they'd not be ideal for use long term. I took them off after 140k or so as they seemed to be getting a bit sticky. The good second hand replacements I fitted then (as a temporary measure until I rebuilt these... ) are still supple 60k later, which is just as well really!
- maxgreenwood
well i never. I'll go to the foot of our stairs and all that. That top sphere mount bit is cast from something heavy though i think.
Thanks for your services Matt
Arctic Steel has offered me his although he doesn't know what condition they're in - off a TZD which he got and broke and it was never on the road.
Yes, the strut top weighs quite a bit as well, so combined it might weigh over 5kg. Prize, erm, some re-conditioned struts please
Perhaps i'm soooo strong, everything seems light
- x 88
You\'ve removed the upright, right? lol
