Front strut weight
maxgreenwood
Front strut weight
Post by maxgreenwood »
How heavy are BX front struts without the sphere?
You can probably guess where i'm going with this..
namely across the Irish sea :)
'90 16TZS (m), White, 86k
Wooscary
Post by Wooscary »
If you hired an olympic hammer thrower, I reckon it would make it...
maxgreenwood
heavy, then :D
I'm only guessing, but about 5kg each?
maxgreenwood
they're bl :shock: dy heavy i found after lumping them about moving house. i'd say more like 10kg each at least?
I can weigh one of my spares ( :P ) later if you like...
Closest guess wins a jar of used LHM!
maxgreenwood
well don't go out of your way, if you happen to be in the same place as a strut and scales at the same time...
Surprisingly light actually - 3.6kg! I checked on 2 different scales as I didn't believe it, I must be getting weak. This is without the sphere or top mount, just the bare strut.
How do you want to claim your prize Mulley? :lol:
If you needed one desperately to get you out of trouble I'd be prepared to loan you one, but they'd not be ideal for use long term. I took them off after 140k or so as they seemed to be getting a bit sticky. The good second hand replacements I fitted then (as a temporary measure until I rebuilt these... :oops: ) are still supple 60k later, which is just as well really!
maxgreenwood
well i never. I'll go to the foot of our stairs and all that. That top sphere mount bit is cast from something heavy though i think.
Thanks for your services Matt
Arctic Steel has offered me his although he doesn't know what condition they're in - off a TZD which he got and broke and it was never on the road.
Yes, the strut top weighs quite a bit as well, so combined it might weigh over 5kg. Prize, erm, some re-conditioned struts please :lol:
Perhaps i'm soooo strong, everything seems light :wink: :lol:
You\'ve removed the upright, right? lol
