BX GTi 16V 1988 from Slovakia
TycoonX
Post by TycoonX »
now it doesnt matter, i wanted to put controls of trip computer to steering wheel, but i placed them near fog light switch on the left
btw: car goes to garage from 1 year parking :) im starting :)
BX GTi 16V 1988
Xantia 2.0 HDi Exclusive 1999
C5 2.2 HDi Exclusive 2002
TycoonX
Post by TycoonX »
news: engine is already here: http://www.skrabsky.sk/ponuka.htm
after 2-3 weeks i have a new 16V engine :)
BX GTi 16V 1988
TycoonX
Post by TycoonX »
news:
new windscreen
engine after overhaul:
new liners,new main bearings, new valves and all gaskets
new water pump, belt and (i dont know whats that rotating things name in english..)
board computer not connected
new clutch by LUK repset .. litlle rusty .it waited for a long time
cable and digital output from XM for board computer
new alternator ,starter, oil measure thing...
litlle modified MK2 bumper, waiting for paint
cleaned and painted inlet
now i must wait for another vacancy..
BX GTi 16V 1988
TycoonX
Post by TycoonX »
4/2011
im thinking about change LDS over LHM.. LDS is fully synthetic hydraulic oil for citroen C5 and newer..
engine completed
BX GTi 16V 1988
Nice job, nothing quite like an immaculately clean engine bay & engine :D
Why are you thinking of changing to lds? I thought it was quite a bit more expensive than lhm & won't the current hydraulic set-up fail as lds is quite diffferent, seems like a lot of potential extra work & hassle for no benefit?
TycoonX
Post by TycoonX »
LHM is mineral based oil, and have changing period about 60 000kms, LDS is fully synthetic, and in C5 have period about 200 000kms ..and theoretically the parts will be in better condition than with lhm.. i think
BX GTi 16V 1988
No idea tbh, i'd heard that if you put in lhm into an lds car it buggered everything up, thats why i thought the same thing would happen the other way round. If i'm wrong fair enough & look forward to some more posts about how you are going to do it & what modifications if any you'll have to do. Perhaps various seals might not work? It would make a change to see an orange stain on a drive rather than a green one :wink:
TycoonX
Post by TycoonX »
thats what im afraid of.. lds and lhm are not mixable..and i cant get out all lhm from system.. so, i will use lhm for this time because its cheaper and i plan litlle changes on hydraulic circle.. some antisink spheres from xantia, and maybe hydractive :P
now im getting informations about anti sink and hydractive modifications.. one man from czech bxclub have it,
BX GTi 16V 1988
TycoonX
Post by TycoonX »
so changing the LDS for LHM is impossible..
BX GTi 16V 1988
TycoonX
Post by TycoonX »
i have a litlle question.. can i use plastic fuel pipes from 406 HDi ? mine is totally rusty and find new one is impossible..
BX GTi 16V 1988
TycoonX
Post by TycoonX »
slideshow of repairs 2009-2011
rate..ehm like pls :)
BX GTi 16V 1988
frog
x 12
Post by frog »
Hey TycoonX,
Is the LDS conversion impossible because you can't remove all the LHM? or because you LHM parts aren't compatible with LDS? and if they aren't compatible do you know why?
I've been wondering if a new electric high pressure pump from a C5 could be put in a BX and run on LHM.
Also if you have anymore pictures and information on the Hydractive activa type suspension I'd love to see it.
Cheers,
1989 Citroën BX 16v
1993 Citroën BX 16v project
TycoonX
Post by TycoonX »
C5 is too complicated.. not the hydraulic circuit but the electronics , electric pump is operated by BHI (block hydraulique integree) and the BHI is operated by BSI central electronic unit.. too many cables and work to get it run
yes i cant remove all LHM, and the lhm and lds are not mixable (few people filled C5 with LHM and have a big problem :D ) so i think with bx will be the same problem
if you are looking for hydractive its easier is to apply older version of hydractive, similar is xantia hydractive but still more complicated..and runs on LHM
BX GTi 16V 1988
Jeth
Post by Jeth »
We've tried LDS to LHM car and we dont have any problems with it.
Other car is XM and other Xantia Activa.
XM got LDS about 4 years ago, Activa got it 1 year ago.
We didn't get all LHM out of the system.
And as we're in Finland, there sure is all kinds of weather, -30 celsius to +30 celcius :P
I wouldn't try putting LHM to LDS car tho :P
TycoonX
Post by TycoonX »
hmm..this info comes too late :) i putted LHM.. maybe next time..
how the car is riding ? its better ? the same ?
BX GTi 16V 1988
