Could this happen to a BX?
Dickster665
This thread appeared on Aussiefrogs http://www.aussiefrogs.com/forum/showthread.php?t=89347
Could a BX manage to propel a suspension strut into the bonnet? Having seen what carnage such a failure caused to a steel bonnet, I don't fancy that a plastic bonnet would fare so well.
If this type of failure can occur, what sort of component inspection/replacement is required to lower the risk?
Dicky
Dicky
Gibbo2286
Linegeist
This is a well-known issue and is simply the Macpherson strut punching through a rotten suspension turret. IIRC, most Macpherson setups can do this in cases of advanced corrosion.
It's nothing to do with the hydraulics - it's just a gravity thing (coupled with rubbish UK roads). IT's pretty annoying when it happens though, as it tends to ruin the paintwork on the bonnet.
Bob the reason this is so dramatic on aXANT or XM is the strut is under hydraulic presure,
it doesnt usualy happen as dramaticly on a conventional Mcy strut as the shockabsourber does not have the same sort of push, as it only controls the coil spring rebound,
and no Matt
more offten than not what happens is the rubber starts to de/bond then damp/water gets in and rotts the metal sections,
and as yet i have never seen a BX do this,
and no Matt
rmattila
It's not the shock absorber, but rather the coil spring that exerts the upward force on a conventional MacPherson strut. However, compared to the proper hydropneumatic variant (which becomes a missile when set free), the coil spring has a limited travel, and thus the consequences of the said event on a vehicle with iron-age suspension are typically rather less spectacular.citronut wrote:it doesnt usualy happen as dramaticly on a conventional Mcy strut as the shockabsourber does not have the same sort of push, as it only controls the coil spring rebound,
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
and usualy the coil spring upper seat is under the inner wing turret,
and the lower mount is welded to the strut/leg body,
so the spring is trying to push the leg/strut body away and downwards from under the inner wing,
Linegeist
Dickster665
Since I am in Australia the likelihood of the suspension mounting position in chassis or the suspension top mount corroding to the point of failure before the rubber buffer inside fails is remote. So if the rubber failed could the suspension escape through the hole in the top?
This is what they seem to be saying in the 'Aussiefrogs' thread that it was a rubber failure rather than a corrosion related issue.
I am afraid it is a bit hypothetical as I live in the driest state in the driest continent in the world the conditions are very different to Britain So a rubber failure has probably not been experienced over there. I am just hoping that someone who has removed front suspension units on a regular basis could clarify whether it is possible or not.
Are the top mounting assemblies expensive?
Dicky
Dicky
as you say its a diferent situation pver there to here, but if it has been on Aussiefrogs im sure it is probable,
it realy depends on the diaminters of the openning's of the metal parts inside the bonded rubber, to what will go were if the rubber de/laminates/breaks up,
last time i checked the price they were around the £140 ish quid over here anyway,
Dickster665
smiffy1071
- pies are evil!
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
Shane might bite if you tell him you like XMs...smiffy1071 wrote:Dicky, why not have a chat with either Shane on aussiefrogs, he doesn't bite....honest! or EricBM, also on aussie frogs... he lives not far from you, and I think he has a uk model BX TZD
Ray
www.citroencarclub.co.uk
