Since getting my car back from the garage the Brake lights have been out, I wondered if they might have dislodged something around the brake pedal area whilst changing the octopus. The fuses are all ok. Unlikely two bulbs would go together. Does anybody know is there a weak point in the feed to the brake lights?
I'd rather it was a quick fix by myself i'm sick of having this car in the garage! I have apparently also got a porous exhaust
My wallet also seems to have become porous and exhausted.
'90 16TZS (m), White, 86k
Check the bulbs first, then look under at the brake switch, you could also check the the connections on the rear lamp bulb holders are pushed on properly.
if the garage only did the octapussy, theyt had no reason to go under the dash and around the pedels, and there is nout under/behind the engine that it relavent to the brake lights,
Measure the input of the switch, output of the switch and input of the bulbs, and then you have the fault pretty much cornered.
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
It's worth just trying replacing one of the bulbs first before delving deeper. Do it on the nearside cluster as the feed to the offside is via this and you will be able to ascertain whether any plugs are loose at the same time.
Porous exhaust? Is that another expression for badly rusted? When is your MOT due?
Success! After checking bulbs i took the brake light pedal switch apart, de-gunked and cleaned it and all sorted. Very satisfying doing these little jobs.
Parts on the BX are very simply made and easy to take apart. The Saab is similar although the build quality is much more solid with lots of novel design solutions. The steel used is about 10 times thicker than the BX! It's like a tank in comparison, more safety, less economy, although the excellent BX brakes make it feel safer than many cars in my opinion.
citronut wrote:sitting at junctions with your foot on the brake can cause the brake light switch to get too hot, which can melt the plastic components,
