Front Spheres
Ian_Fearn
Post by Ian_Fearn »
i've had sucess with chain wrenches on all but 1 off the many spheres i've removed.
That 1 sphere cost me about 4 chain wrenches until Pleiades delivered my 35quid tool.
I'll never go back now!!
Over and out from me
Brian
Post by Brian »
Hi,
I posted a picture showing 2 that I made, and work well..
It's under "Hints and Tips" section
Brian
http://www.frenchcarforum.co.uk/forum/v ... php?t=8655
ellevie
Forum Treasurer
Post by ellevie »
That looks like a pretty neat solution Brian. It must be really satisfying when you can make your own tools. Perhaps there should be a Citroen sphere custom tool competition !
David
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
sleepy0905
Post by sleepy0905 »
Hi thanks ken for the spheres and the suspension parts.
Toddman
wrench
Post by Toddman »
Don't know if there is enough room on the rear spheres but for the fronts I use a large set of water pump plier -absolute doddle.
Luke
Please call me Luke :)
http://www.bx16valve.com
Mike E (uk)
Post by Mike E (uk) »
Pliades have hikedup the price of their tool, but I suppose I did buy it many years ago.
Still worth buying though, as it is much less than 1 hour labor at a franchised garage, and a good tool to share with local Cit fans.
Mike
ellevie
Forum Treasurer
Post by ellevie »
Here is another contender as a sphere removal tool from Draper Tools. This might work well with the heavy duty wheel brace from Halfords (£5/£6) which has a 30" telescopic handle and comes with two 17/19 mm and 21/23mm reversible sockets driven by a 1/2" drive.
Draper Tools
300MM CAPACITY OIL FILTER STRAP WRENCH
Stock number: 56137
Part Number: OFW 300
Price: £8.41
Heavy duty webbing strap 1000mm x 38mm with 3/8“ x 1/2“ square drive/21mm x 13/16“ AF cam for tightening. Cam has plated finish for corrosion protection. Display packed.
David
BX19TXD 150k K Reg
ellevie
Forum Treasurer
Post by ellevie »
Also from Draper Tools...
100MM CAPACITY OIL FILTER WRENCH
Stock number: 10784
Part Number: OFW 100
Price: £6.03
A quality wrench manufactured from heavy gauge pressed steel hardened, tempered and matt chrome plated finish. The automatic action clamping ring has a serrated inner surface for secure grip. Fits most oil filters. Display packed.
Image resized and uploaded to BXCserver JW
David
BX19TXD 150k K Reg
Oscar
Post by Oscar »
I used an old cambelt and a mole grips. Worked really well - on the first sphere. I took the other 4 off with a hammer and chisel....
ellevie
Forum Treasurer
Post by ellevie »
It looks as if the capacitiy of the last one (OFW 100) at 100mm is just too small. Pity...
David
BX19TXD 150k K Reg
monkeyfeet
splash out, save your knuckles
Post by monkeyfeet »
Probably too late now, but I bought the Pleiades tool- pricey maybe but it's the best for the job, and I've tried and broken a few over the years, inc the draper strap wrench.Even the rears (spheres) on 2 bxs and a xantia were easy peasy! (and no, I'm not connected to Pleiades)
sleepy0905
thanks for the advice but the job is done and dusted. :D :D
