St Tropez wheel
Des Smith
St Tropez wheel
Post by Des Smith »
I've been prepping the BX for our French adventure next month and the spare wheel has been getting some close attention. Took it to the tyre man and it is slightly dished. Presumably a previous owner hit the kerb and swapped it with the original spare. Anyway, I am on the lookout for another steel wheel to match. The existing one will work as a spare for the time being but I am always a bit twitchy when I know something is not quite right.
Any ideas?
Xsara Forte 1.4i 2000
Kawasaki GPz550A4 1987
Well, your local breaker will have a wheel I'm sure as it's a common size. A lot of Fords and Pugs share the dimensions. PCD 4 x 108, 15-22 ET with a 65mm central hole. 14" of course.
Des Smith
Post by Des Smith »
Thanks Phil. I did wonder how generic it was. The existing one however, was nearer 13.9 inches with the flat spot!! I will ask around.
Ive got one Des, with good tyre, yours for £10 if you collect it.
scarecrow
Post by scarecrow »
I've got one for free with a naff tyre - just to give you a choice :)
Des Smith
Post by Des Smith »
Both sound great to me. Will PM. :D
Des Smith
Post by Des Smith »
Thanks for the wheel and the cuppa, Steve! Great to meet you, have a chat and see your lovely 14TGE as well. The wheel has now had the spare tyre fitted, balanced and cleaned. Much appreciated!! :D :D :D
scarecrow
Post by scarecrow »
You're welcome! It was nice to see a St Tropez too.
