Crap photo, but hopefully you get the idea - I even bent back the metal casing to try and make it work, but still no joy
The central locking solenoid works, so that's one less thing
That's a good idea Ken, should take some of the stress away from the cracked area around the catch hopefully.ken newbold wrote:That's a general fault with most BX estates, due to the weight of the tailgate; these are incredibly heavy. It really used to annoy me when people would slam mine shut, there's simply no need, gravity does the job all too well.
On the good news front, the two lower bolts can be removed and long bolts fitted right through the tailgate to hold it tight if needs be, they'll come out behind the rear bumper trim that sits on the lower edge of the tailgate, bit of drilling required but easy enough
