1990 Black Citroen BX 19 TZD ebay
I see both sides, theres no bigger BX fan than me (sorry but I do have a problem :lol: ) but there is always that niggling feeling in the back of your mind with any old car that what if?, and with any hydraulic Citroen there IS more to go wrong than say a Ford/Peugeot, which if it were to pop a pipe etc it could leave you stranded.
Saying that in 15 years of BX ownership ive never failed to get where im going, but I dont do that many miles in them, would I buy a BX if it wasnt running on green blood? probably not so its a vicious circle.
If a Citroen doesnt have a ride heigh lever then it aint for me :wink:
anaconda
Post by anaconda »
Defender110 wrote:
mat_fenwick wrote:I reckon close to £1000 - the working A/C will be a sales point too.
Good point i'd forgotten about the A/C, this potentially opens it up to a current BX owner who although not normally in the market would like to upgrade to this rare option.
mat_fenwick wrote:Can we keep the discussion more about the car? (Although I'm guilty too!) It's an argument that doesn't have a right or wrong answer.
I'm enjoying the debate and althought it may not have a right or wrong answer it is a very prominent part of BX ownership that well deserves discussion IMHO and which we can be in no doubt is the reason it has been raised.
Isnt the air con a bit of a bugger on the BX? Reliability?
Id quite like air con. We'll be doing a lot of driving around France so it would be a real plus.
On the subject of car price etc. If a low mileage white mint BX diesel saloon (with good air con!) came along Id be very tempted to part with over a thousand. The point being we all have our own values on these things and Im willing to pay decent coin for precisely the right beast.
So if anyone know of one, im still in the market!
1991 BX TGD Saloon
1990 VW T25 Camper. Currently on sabbatical
anaconda wrote:Isnt the air con a bit of a bugger on the BX? Reliability?
I've done about 60k miles with mine since I installed the A/C (from a donor car with 200k on the clock) and the only problem I've had was the operating switch. Quickly replaced and still working fine. It could be argued that it is an aid to overall reliability of the car, as it enables you to turn on the radiator fans manually if the fan switch should fail.
I'm enjoying the debate too, there are some very valid points raised. I just wanted to steer it away from any danger of personal attacks...
Keeper of the site Goat
Post by cavmad »
BX Meteor wrote:
Once more I state. A BX is not a car that you can rely on as a sole car to get to work each day, because it has an extra risk in an ageing component that is not in other cars of that age and is not visible. You need to have that replaced to make it equal to other cars of that age in terms of reliability. Read all my posts in this tedious thread and you will see that I have to keep making these points over and over and over ....... ](*,)
Say what? I've used countless old BXs daily for work, pleasure driving and holidays as I'm sure 99% of people on here have too.
I haven't read through all your posts but in all honesty if you don't thinka BX is any good for daily use you really are on the wrong forum.
Vauxhall apologist.
I think the problem here is that the original statement (and the back up) come from someone who is convinced that HE can't use a BX regularly. That's fair enough. It's a personal choice. But to suggest that no-one can use one regularly is incorrect and frankly a little insulting.
What I find most depressing is that even in hydro-Cit circles, there are people here convinced that complete catastrophic suspension failure is only moments away. I reckon I'm getting on for at least 40,000 miles in hydraulic Citroens and have NEVER had a major suspension issue develop. I bought a BX for £266, gave it a service, replaced a strut return (which was only weeping anyway) and drove it over 3000 miles around France, treating it to another 12,000 in regular use because I was so impressed with it when I got back home. Even when a rear suspension unit sprung a leak for the new owner, he was able to drive the car to a garage for it to be repaired.
Roverman wrote: Saying that in 15 years of BX ownership ive never failed to get where im going, :wink:
Yeah, but even you have had a close shave I seem to remember Tim
:D
philhod
Post by philhod »
:lol: :lol: :lol: Really have to laugh at this thread.
For fucks sake cool it.
If you don't like the octopus, make a new one out of aluminium and replace the one Citroen produced in the first place, which is not that unreliable
Cures the problem permanently. I have, or had, a drawing somewhere. I 'll have a look if anyones interested.
67 and still rockin (but not in a chair)
I've never seen Doc clean shaven? :lol:
there was SOME beardage :(
erm, I've run BX's as my only cars since I was 17. I still have my first, which I bought from my dad, and STILL use it DAILY. It's done OVER 1 million miles, and has NEVER failed to get me home. Sure, I've spent a bit on it, and replaced thngs usually befire they need changing. But none the less, i would have no issues at all about going anywhere in that car.
Hell, even my "fun" 16 valve I'd happily take anywhere. I have no breakdown cover, dont feel I need it never have.
Yes I regularly drive other vehicles (I look after a large number of cars) and I drive buses for a living, so I drive lots of stuff daily. I also drive over 30 miles each way to work. In my 22 year old BX.
Ok, so it has hydraulics? and? It's no more likely to fail than any other mechanical component. I'd rather have an octopus than 30 computers or multiplex wiring. and yes I DAILY drive past broken down cars on the M5, oddly enough, most of them are shiny modern things..
Octopus is piss easy to check. Piss easy to replace (I can do one on less than an hour) and HP pipes can corrode? and? so can brake pipes on a "normal" car.. Since all of mine are kunifer I tend not to worry.
The arguement has no merit. Anything mechincal can and will fail. Thats life. A BX is n more or less reliable than a brand new BMW, which can and do fail.
Would I want a car that requires a laptop to tell me whats wrong? no thanks.
A BX is a simple car to work on, and fault finding and diagnosis is simple. Repairs are simple, and as for reliability, I'll stick with a BX thanks.
If piss easy stuff like an octopus scares you, maybe BX ownership just isn't for you?
apols on the spelling, I've had a few!
Well I think that ends that argument :roll:
A million miles?...Triggers brush :?: :lol:
messerschmitt owner
Post by messerschmitt owner »
I'm on my sixth BX now - three of them went from 30-40k up to nudging 200k in my ownership - all sold on for future life.
My BX isn't my everyday car, my XM is - so there!
I once had a major hydraulic failure in a BX - and yes you have no brakes, or suspension (and the steering gets a bit heavy) but the RAC/AA/Green Flag is there for such an eventuality.
My BX and XM are more reliable than my 2005 smart roadster (which is broken yet again).
Regular maintenance and checking alleviate some of the problems that afflict any older car but all cars can fail with terminal roadside issues that require a tow or recovery. I'd always rather go for the recovery option than the tow one.
Anyway, no offence but someone is on the wrong forum and owns the wrong car ...
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
I'm feeling picked on :D
show your friendly octopus some love
You bastard. I feel really old now... :evil:
Watch it, you'll be on a register soon :roll:
