Its a longshot which I know is possible in NZ so will give it a try asking here as I can not find it via the net.
The 19TXD I own has a previous history in the UK for about 3 years. I have some details of previous history from the UK just wanted to see what else I could find out about the vehicles history before coming to little ole NZ.
Is there and would the DVLA hold any records for the early 90s then again I may get lucky and find some mechanical history from someone on here.
Previous owner checking
1990 BX19 TZS Auto 06/11/1989
Re: Previous owner checking
Hi Kiwi, the only extra info you may get via the net is the MOT history status/advisory's provided its been regularly on the road/mot'd to, but only from the period the MOT's where registered/timed (Via connecting up to VOSA, for the duration of the mot at the testing station) !kiwi wrote:Its a longshot which I know is possible in NZ so will give it a try asking here as I can not find it via the net.
You will need the UK car registration and the V5 document ref. (Or MOT test number from the VT20 test certificate/VT30 refusal certificate) to do this though, here is the LINK !
I hope may be of help to you and others ?
All I have is the old UK registration number and a service booklet thats about it and well looks like this may not be possible.RxBX wrote:Hi Kiwi, the only extra info you may get via the net is the MOT history status/advisory's provided its been regularly on the road/mot'd to, but only from the period the MOT's where registered/timed (Via connecting up to VOSA, for the duration of the mot at the testing station) !kiwi wrote:Its a longshot which I know is possible in NZ so will give it a try asking here as I can not find it via the net.
Tell you what though it is a good feeling being sat in something that spent some time on the UK roads and I guess if cars had souls could tell you how much more fun UK roads were.
- citsncycles
Or how congested, how many times it was clamped or ticketed, how many hours sat in contraflows, how often it was caught on a speed camera...if cars had souls could tell you how much more fun UK roads were.
