When I fill the Red Baron up, it leaks fuel from the top of the filler neck. Is there a plastic/rubbery gasket up there? I imagine it's a case of letting the fuel level drop sufficiently before investigating further: Is it a case of disassembling the top /cap end (there doesn't appear to be much in the way of corrosion or any damage I can see) and reassembling tightly having cleaned the area up?
This isn't the first Cit I've had to suffer from this: The Visa GTi was appalling in that respect.
Any hints, tips, diagrams would be helpful. In the meantime I'll refrain from filling the tank more than halfway.
Fuel filler neck leak
- x 25
- x 25
Stinkwheel
Phil,
My car had this problem, The actual plastic filler neck had fractured. The solution was a good used item.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
