BX compatible ignition barrel
Boxwolf
Post by Boxwolf »
As I have documented in the technical section, my BX is now short of an ignition barrel. The electric side is still fine, but I need a replacement for the mechanical bit where the key goes in.
Does anyone know what other citroen/peugeot models use the same one and the best place to get a nice crucifix type one?
1992 BX TXD Turbo
I just had this issue. Be careful when buying a Valeo unit from places like ebay - there is a kit they did that came with all locks EXCEPT the ignition barrel/switch combo!
The one that did come complete is normally around £80. It\'s a full kit, so all matching keys. Bad news is they\'re a bugger to find and they\'re discontinued. Luckily Jaba is a bit of a legend and sold me one he\'d bought as a spare. I\'m sending him my old lock set (when I stop having kids and moving houses I\'ll remove the last two locks) and I believe he\'s going to try and overhaul the unit.
FYI, the AX ones are pretty similar, but the housing is different so the steering lock is non-compatible. If you strip them down, it might be possible to make one out of the two.
Best of luck to you!
bxzx16v
Post by bxzx16v »
Just had my (Xantia,Dispatch)barrels rebuilt at a locksmiths there as new now and cost £15 each , not sure if it's possible with the Bx ones though , it might be worth enquiring
Mark
Post by citronut »
GSF used to do a Valeo ignition lock/switch on its own or a door lock set,
x 80
GSF are listing an ignition lock/switch with a stock of two at £88.20
Their part # is 928PC0050. They still do the car club discount of 10% I believe.
Don't throw the old lock away as I would like to have a go at it to see if I can resurrect it somehow from my box of bits from failed switch barrels.
I want to do the same from Kitch's switch as well. If successful then there will be a couple of working units available for our BXs.
GSF have no stock, I've tried several times to get a set out of them to no avail..
Same with AEP, ECP and every old fashined motor factor I can find..
Boxwolf
Post by Boxwolf »
Jaba, not sure you will want this one! it has been pulverised with a hammer in order to extract it from the housing in the steering column :oops:
The one that was in there didn't have the steering lock pin fitted (i tried and failed to fit it when i replaced the barrel last time it broke) so I don't know if that makes it easier to find a replacement?
1992 BX TXD Turbo
Post by ken newbold »
You might just be lucky, there could be one in my garage, I'll check tomorrow. :?
x 80
Boxwolf wrote:Jaba, not sure you will want this one! it has been pulverised with a hammer in order to extract it from the housing in the steering column
Still, yes please there will be something to salvage I am sure.
You could try Malcolm Lockwood if GSF really don't have any left.
Post by RxBX »
Jaba wrote:..................
One HERE but not cheap (Models with-out ABS ) if I'd deciphered it correctly !
thats about the going rate these days.. It's not difficult to add a fly lead for the ABS if it is minus the ABS flylead, and you need it for a car that has ABS.
