BX 16 exhaust
messerschmitt owner
BX 16 exhaust
Post by messerschmitt owner »
Does anyone know of a cheap supplier of a complete system for a BX 16 Auto (and if there is a difference between the auto system and one for a manual car)
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
Post by citronut »
be carefdull of cheap as they probably wont last long,
you could give Barry Aneles of Bourne citroen a call as he had a pile of new OE old stock BX exhausts,
http://www.bourne-citroen-centre.co.uk/
otherwise try Malcolm Lockwood
messerschmitt owner
I'll call Bourne tomorrow - today I may venture underneath with a baked bean can in hand
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
The manual and auto are the same exhaust as far as Im concerned, as mentioned I'm sure Barry has plenty of BX exhausts, failing that ebay may turn up a few parts.
Before fitting new exhaust boxes I always paint them to keep the rust at bay that little bit longer.
messerschmitt owner
Tim
Just eaten my baked beans and fitted repair section - the pipe had totally split - looking at mine I have a long downpipe and the back box with no middle box. All of the diagrams imply I should have another centre box but there looks like no space to fit one.
As far as I can tell too, the back box is the same regardless of BX engine.
I still have a slight blow further down where the front and rear sections fit - but at least car is roadworthy again.
Campbell
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
The exhaust design is the same on all BX's hatches but with different front pipes, from there backwards there are two different sorts, carb petrol (and 16TXI) and non turbo diesel and then for 1.9 injection models and T/D.
The middle box is a "cross box" that sits in front of the spare wheel carrier.
messerschmitt owner
ah, mine is straight through, which may explain the rubbish alignment at the back!
I remember having that box on the diesels years ago now.
Someone did it on the cheap last time ...
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
