Pipe and Connectors supplier?
hvanman
Hi, I am going to need to splice in some new high pressure pipe, but now that pleiades is no longer around, could anyone suggest a good source for male connectors, female joiners and a length of 3.5mm pipe?
Thanks, Simon
Thanks, Simon
hvanman
Thanks Kevan, sadly I can't see any 3.5mm products on their web site that could be used to joint the existing pipes...Defender110 wrote:http://www.beal.org.uk/hoses-tubing-fit ... at_30.html
hvanman
Thanks, I will try them tomorrow, but found this on the web:-Roverman wrote:As far as I know Pleiades they are still going
01487 831239.
http://www.geolocation.ws/v/W/4d76bc658 ... ent-the/en
NeilGP
- x 3
hvanman
they actualy just moved premises a while ago, i think that was when people were haveing trouble contacting them/Martin,
as i have never had any probs and found there service second to non,
I'm sure the 1/8 (3.2mm) or the 4mm nylon tube would easily do with the tollerances in the connectors.hvanman wrote:Thanks Kevan, sadly I can't see any 3.5mm products on their web site that could be used to joint the existing pipes...Defender110 wrote:http://www.beal.org.uk/hoses-tubing-fit ... at_30.html
hvanman
KevR
- x 4
No!hvanman wrote:This is for the high pressure system, is nylon suitable?
Well it's what is used for all the very high pressure air brake systems on all HGV trucks and coaches and I've never had one burst, rub through yes but burst no!hvanman wrote:This is for the high pressure system, is nylon suitable?
''Suitable for lube, air & fuel line''.
W.P. = working pressure.
OD, ID, W.P. OD, ID, W.P.
4mm 2.5mm 26 bar (377 PSI) 1/8" 0.058" 43 bar (623.5 PSI)
KevR
- x 4
Yebbut, isn't a Cit suspension system working at about 15 times the pressure of an HGV air brake system...?Defender110 wrote:Well it's what is used for all the very high pressure air brake systems on all HGV trucks and coaches and I've never had one burst, rub through yes but burst no!hvanman wrote:This is for the high pressure system, is nylon suitable?
