Wanted, Front Brake discs & other
hvanman
Hi, I am slowly getting to grips with my new BX 19RD, although I seem to find more challenges at every visit....
I have a bit of an initial list of parts I need to try and get it through an MOT and also generally improve her and have just purchased new track rods, belts, filters and brake pads, but....
The front discs are pretty rough, so before heading into eBay I thought I should check here...
Less important parts needed include:-
A rear washer bottle as mine has split.
A light grey glove box lid as the hinge has broken.
Cheers, Simon
Cheers, Simon
The brake discs are readily available from your lolcal factor, buying discs on ebay is problamatic because of the weight hence high postage costs.
hvanman
Simon, whereabouts are you located? That might help in club members possibly being able to offer you some of these parts if they are localish to you.
You should be able to find front discs for around £20 the pair, i'd be surprised if local factors can match e-bay prices even taking into account the postage. Again, brake pads should be available for under £10, off e-bay rather than motor factors, but who knows, you might find somewhere local to you that comes in a bit cheaper if they are wanting to get rid of old stock. My last pair of discs were citroen oem & inc postage cost me £20. I think i got lucky with the pads & they cost me £6 inclusive of postage
I don't agree with you Kevan !Defender110 wrote:The brake discs are readily available from your local factor, buying discs on ebay is problamatic because of the weight hence high postage costs.
A pair for £17.90 (BIN) on E-BAY delivered to your front door, it will save you the time/fuel driving to your motor factors, also a pair of REAR discs for £13.25 (BIN) if anyone needs a set (Very reasonable IMHO)
Those listings are a bit misleading, the front is just for a single disc, so its a bit priicey in my book, the rears don't look right to me. Whats that different colured corrugated pattern on them?? Never had rears with that on, so its either a picture of the wrong one's, or they aren't for the bx?
Anyway's, i agree with you Richard, theres plenty of cheap discs front & rear & pads which i don't think a local factors can touch on price. I'll stand corrected of course if a local factors near to a club member has some cheap deals going.
Matt you may/may-not be correct as I did look for a pair as it does stateMULLEY wrote:Those listings are a bit misleading, the front is just for a single disc, so its a bit pricey in my book, the rears don't look right to me. Whats that different coloured corrugated pattern on them?? Never had rears with that on, so its either a picture of the wrong one's, or they aren't for the bx?
But then in the general description it does state "Here we have a brand new Front Brake Disc for the following ....." so if it's not for a pair the seller is crafty being ambiguous (But you could always call them first 01732 810224 , before buying/committing to a purchase) !E-Bay seller wrote:Citroen BX Pair of Front Brake Disc #4884
So if the above, is only for one ? go for a safe bet with the GSF listing at £13.80 each with free delivery !
I stand corrected, they are cheap
''Picture is for illustration purposes only''MULLEY wrote:Whats that different colured corrugated pattern on them?? Never had rears with that on, so its either a picture of the wrong one's, or they aren't for the bx?
Hi simon,hvanman wrote:......................
Cheers, Simon
I have just checked my spares stock and I do have one available complete with a working pump !
However as both front and rear washer bottles are of an identical moulding (other than which side the pump is mounted) I need to choose/select the correct one for you, PM sent !
hvanman
My local factor is a real "old school" joint, but have often beaten the internet for things like batterys, so I might give them a try, but the best deal I found on eBay was for a pair sub £18, which is not bad going...MULLEY wrote:Those listings are a bit misleading, the front is just for a single disc, so its a bit priicey in my book, the rears don't look right to me. Whats that different colured corrugated pattern on them?? Never had rears with that on, so its either a picture of the wrong one's, or they aren't for the bx?
hvanman
Hi Matthew, good point, I'm based in Bedfordshire.MULLEY wrote:Simon, whereabouts are you located? That might help in club members possibly being able to offer you some of these parts if they are localish to you.
You should be able to find front discs for around £20 the pair, i'd be surprised if local factors can match e-bay prices even taking into account the postage. Again, brake pads should be available for under £10, off e-bay rather than motor factors, but who knows, you might find somewhere local to you that comes in a bit cheaper if they are wanting to get rid of old stock. My last pair of discs were Citroën oem & inc postage cost me £20. I think i got lucky with the pads & they cost me £6 inclusive of postage
In that case to prove my point; my local factor in Manchester sells them for a tenner a pair but doesn't do mail order or delivery!hvanman wrote:Hi Matthew, good point, I'm based in Bedfordshire.
I might have to put an order in with you Kevan
