Interior Lights
hvanman
Interior Lights
Post by hvanman »
Hi, I have a very strange problem with my interior lights on my 1.7 TZD Turbo Estate.
They do not operate when either front door is opened, however they work if you operate the switch on the light itself, but the door switches are also working fine as the dash door indicator works and the lights-on warning operates, so I can't work out why they don't work when the doors are opened?
Any ideas anyone....
Cheers, Simon
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
1992 BX 17 TZD Turbo
First of all, the door open warning lights are operated by a switch in the lock mechanism, not the one on the pillar. I suspect a high resistance switch which allows the small amount of current to flow that's needed for the lights on beeper, but not enough to light the bulb. Try shorting out the wire behind the door switch to a good earth - if it lights then the switch is your problem.
hvanman
Post by hvanman »
Great, thanks for the suggestion, that door open panel was leading me astray....
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
hvanman
Post by hvanman »
Well I put the door switch wire to a good earth and no joy. None of the 4 door switches operate the lights.
I put an earth to the relevant contact on the back of one of the lights and all 3 came on, so I am guessing that somewhere there is a point where all 4 door switch wires join onto a feed to the lights and this is at fault, does anyone know where this might be located?
Thanks, Simon
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
Onto guesswork here, but I'm now wondering whether the problem lies with or around the interior lamp delay unit? As there is obviously some current passing through the switches, and a corroded high resistance contact is less likely inside the car.
If the lights work as expected from the rear doors that would tend to rule out the unit itself. I don't know at what point the wires split to operate the lights on beeper, but the problem would appear to be after this point...
hvanman
Post by hvanman »
Yes I had a look at the wiring diagram and that seemed a likely culprit, as the rear doors do not operate the lights either, so it seems to be a common point if I can find it!!
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
KevR
Post by KevR »
Is the delay relay the one attached to the back of the dash between the top of the glovebox and the side of the heater control unit?
I hadn't realised the door open light was controlled by a separate switch from the interior lights - my driver's door light has been permanently on for months, and I'd been scratching my head trying to work out why!
Post by ken newbold »
KevR wrote:Is the delay relay the one attached to the back of the dash between the top of the glovebox and the side of the heater control unit?
Yes
hvanman
Post by hvanman »
Thanks for the location advice, nice easy fix, the plug to the unit was half out! However also found one of the door switch contacts had got some light rust and was not making contact, so a quick clean and all doors working lights properly now. Simon
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
