Thought as much
Anuvva question So if it fails its mot within the 12mth original mot, does that mean that you can drive the car until the original 12 mot period runs out, or does the earlier mot mean you can't?
MOT
- x 148
Once an MOT test has been failed thats your lot, even if the current "ticket" has 3 months to run. You then legally can only drive it to and from the place of repair.MULLEY wrote:Thought as much
Yes and no is the legal answer!
If you fail an MOT but still have another month or so left to run, the original certificate is still valid but it IS an offence to drive a vehicle in an unroadworthy condition (whether knowingly or not). But if you then rectify that fault, you are then perfectly legal again for the duration of the original MOT, without having to get a retest.
So you can't be done for having no MOT, but you could be done for having an unroadworthy vehicle...
Think i'll just keep on doing what i've been doing which is to just get the car mot'd when its due, but still useful to know though.
