After Ken`s kind assistance in getting my handbrake to work properly for the re-test on the estate I duly drove it around for a while and gave it a few good stomps on the brakes.
Taken it back for a (hand)brake check before I pay for the MOT again and the tester said brake imbalance was `at best` (after he`d also tried bedding the brakes in again) 36%. Says it needs to be 24% (I think( before it would pass and that he thinks it`s a `lazy caliper`. Not big problem changing the caliper but it is p*ssing me off now as I`ve stated previously the handbrake had never worked so well after the work that`s been done post MOT fail.
Does this `lazy caliper` thing ring true to anyone else? I do have spare ones about and can change it but it`s bloody annoying but a nmeccessary evil I suppose?
BX brake woes (again!)
Vauxhall apologist.
- Barnsley BXer
- sleepy0905
Slides is an easy job to do but yuo'll need a 17mm socket and a lot of grunt to get the bolts off. A mixture of grease and WD40 will do a good job. I'm still trying to find a substitute for the rubber seals that were perished and fell apart when I took my bolts off. I might just use gaffer tape to keep the cr*p out.
Oscar
Oscar
