Front Sub Frame woes
hvanman
Post by hvanman »
Hi, I am wondering if I am jinxed on BX ownership..... After the 19RD disaster, the expensive 17 Turbo estate (and non-existant part of the deal spares) has now had a major disaster.
On a round trip to Harwich (following hitting yet another nasty pothole) the N/S suspension and brakes felt very strange. On checking this morning, the sub frame has broken in two places and is bent.... I can't afford to scrap the car, so need some advice please....
1. Are the sub frames common, or do I need one from an identical car?
2. Is changing the front sub frame a do-able job, or am I going to run into major re-alignment challenges (beyond the other work which I guess includes removing the engine etc?)
3. I may be able to strip a sub frame from a scrap car (model unknown at present), if not, does anyone have a front sub frame.
I will also take it down to my local mechanic just in case he can weld it up, but it looks too awkward to me and may be difficult to straighten out enough to get the alignment back.....
All advice very welcome
Thanks, Simon.
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
1992 BX 17 TZD Turbo
KevR
Post by KevR »
Not 100% sure, but I think the subframes are the same - at least for the larger engine versions. My 1987 TRS 1.6 petrol subframe looked identical to my TD ones and accepted all the TD bits when I converted that car to TD.
Subframe's only mounted via a couple of bolts to the floor and a couple of mounts each side, from memory, plus the engine mounts, and it's easy enough to detach everything and lift the car off the whole engine/transmission/subframe assembly. Alternatively you might be able to leave the engine in and drop the subframe out from under - not sure. I'd be inclined to take the lot out and take the opportunity to clean everything up and check stuff like the octopus, heater hoses, clutch cable etc – all the stuff that's a bastard to get at with the TDs.
If you've got to pay someone to do it, then it's probably not going to be economically viable, but if you can bribe some mates with beer to give you a hand then it's probably do-able in a weekend or so. There shouldn't be any major alignment issues (so long as the mounts on the body are still where they're supposed to be...), but only a proper check after fitting will show whether it needs a tweak.
I have a good used front subframe,complete with with some ancillaries.
hvanman
Post by hvanman »
PM sent.
Does anyone have any advice on the work involved in changing?
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
Oilyspanner
Post by Oilyspanner »
I changed one a while ago, not as bad as you might think, everything stays on the car and the subframe lowers away, there is a good opportunity to replace the octopus at the same time too, you will never see it this clearly again, as said all larger engines are the same and MK2 subframes will fit Mk1 cars.
The beatings will continue until morale improves
hvanman
Post by hvanman »
Thanks. The book says that the anti-roll bar needs a special Citroen tool to re-fit it, is this true?
I guess changing the octopus would be a good idea. Are they still available and if so, where could I get one?
Cheers.
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
Post by citronut »
yep the engine only attaches to the sub frame by its lower stabilizer bush,
as the main engine and box mountings are attached at the top of both inner wings, so with the sub frame removed the engine and box hang on there mounts as they do with the car all together,
also if your second hand sub frame comes complete with anti roll bar you wont need to remoe that either,
you also undo the two rack bolts from underneath which leaves the rack in situe,
there were three diferent sub frames,
two very early ones one is for the suitcase type engine which sits on the sub frame with its mounts,
the second is with taper bearings were the front arms attach,
this will fit your car and any with the engine hanging from the inner wings, but they are probably a bit hard to get hold off these days,
then there is the usual one fitted to all the other model/engine types,
hvanman
Post by hvanman »
That does not sound too bad then, although I suspect access is going to be fun, as I don't have a 4 post lift sadly...
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
smiffy1071
pies are evil!
Post by smiffy1071 »
A 4 post lift wouldn't be that much use to you in any case for this job!!!
Some sturdy axle stands under the body, a decent trolley jack and somewhere to work out of the rain are what's needed!!
hvanman
Post by hvanman »
Sadly workin out of the rain is unlikely, it's the drive or no where.... and I have to liberate my trolly jack from under the h van, having just broken the throttle linkage that forms part of the engine mount!! Still, at least the job does not sound as horrible as I first thought!
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
bx petrol auto saloon
Front Subframe Woes
Dear Simon.
So sorry to hear about your front subframe problems Simon :!: I
have a fairly new 2 1/2 ton trolley jack and a fairly new 1 ton collapsable
engine crane aswell, you could borrow, but I don,t think they would be of
much use to you on this job Simon.
What I would do, if I were in your position of changing the front
subframe, having the car ( if your driveway is flat enough ) on 4 axle
stands, without the car being " too " unstable. and making yourself a
small subframe sized frame, out of, say new fence posts, with obviously
some sort of battening, to hold them all together with another small peice
of wood or metal preferably to put on top of your trolley jack head.
I am at home all day everyday Simon, so If you need to have a
natter over it, please feel free to do so OK :wink:
I hope this helps Simon.
All The Best.
Vince.
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
hvanman
Post by hvanman »
Dear Vince,
Many thanks for the kind offer on the equipment, luckily I don't think this job needs them from what I have heard so far...... My drive is not very flat, but if I can get the H van fixed and out of the way then I should get a flat'ish area. My main concern is supporting the body at the front without damage to it, so I will need to check that out carefully.
It seems that actually not too much is fixed to the sub frame so hopefully a full frame won't be needed but a good idea all the same.
Cheers, Simon.
1954 H Van
1961 2CV AZU
1961 Velosolex
1967 DS19
1981 H Van LWB
1984 Mehari
Post by citronut »
you can support the car on axle stands with a piece of wood on top of them under the chassis rail just behind the sub frame,
mind you choke the rear wheels after the suspension has fully depressurised as the hand brake is on the front,
