Then once the job was done they had to get new LHM from round the corner. I explained that the system would need bleeding and the pipe feeding manually with a funnel, but they would not listen and told me that only brakes need bleeding! Eventually, I just bled it myslelf and told them what to do. Where I really felt ripped off was on replacing the strut return pipes. I saw them do them and they took about 5 minutes a side. He said, I am only going to charge you £50 for the pipes!
Now, I am tackling the Fiat X19 electics and plan to MOT that early August. Just got the pop up headlamp motors to service and brake balance to sort on that..Oh and a severe hot starting problem! At least the BX will be solid for the next few years at least.
