Added to this, we have a long term oil consumption problem that I've run out of ideas trying to solve. Annoying part of all this is that this car absolutely goes like the clappers and has only about 120K odd klms on the speedo and on a compression test it almost blows the needle off the end. After doing all the checks, we've come to the conclusion that it is the oil rings not the valve stem seals and it would seem that this is a common phenomena with low mileage engines in these 1.9s.
The quandry I'm in is, do we rip all the mechanicals out and do a clutch as well as a set of rings, valve stem seals etc and hope that at the end of all this, we have a car with effectively a new engine in it, because if I take it out, I'll automatically do a head plane for flatness and cut the seats and face the valves at the same time, or do we just do the clutch and put up with the oil burning of about 1 litre every 1200 klms?
Normally I'd do the lot, but this guy has bought a ripper Mi16 with 128K klms on the clock with a rebuilt motor that went wrong during the rebuild due to the valve stem seals being fitted incorrectly, so we are also in the middle of redoing that and I'm fast running out of garage space. For the record, my garage is 40ft X 30ft with a large lean to carport out the back and I'm outta space; how ceazy is that??
Once the Mi16 is finished, it has to get some paint touch up and get resold so if we start on the BX prior to finishing the Mi16, he'll be comandeering more garage space than me.
Incidentally, Brad has designed and manufactured a gadget to replace 16V valve stem seals without removing the head. We've been using it on the Mi16 and it works really well.
Alan S
