95563928 (front suspension cylinder support) creaking
ghaddon1701
Post by ghaddon1701 »
Hi everybody,
I have changed the R/H driveshaft recently on my TZD. While we did this we also changed the suspension strut as I thought mine was creaking. The one we have replaced it with is a known good one. However the creak is still there. Has anybody known the suspnsion cylinder support to creak? It is flexible so the strut can move about when the suspension goes up and down. Also does anybody know if it is still available from Citroen or does anybody have one? The part is number 13 in the picture. Part no: 95563928. Thanks.
Regards Graham
barry badger
x 10
Re: 95563928 (front suspension cylinder support) creaking
Post by barry badger »
Creaks are quite often caused by partially seized ball joints. Check the bottom ball joint and anti roll bar link boots for damage to indicate any water ingress. Also the rack knuckle and track rod ends too.
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
Probably the replacement strut again i'm afraid. I've never had a 2nd hand creak free one yet :(
