Spheres
Spheres
What's the age limit for spheres to be ok to use? My GT came with 3 pairs, two dated 2008, two dated 2003 and two undated but marked on the box as rears.
Can't get them tested until the car is on the road, so for now i'll either have to fit these (sealed non re-gassing types) and make do or buy new ones.
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
Re: Spheres
Unfortunately I would say iy is pure luck of the draw. They may be perfectly sealed and hold full pressure they may have leaked a littyle pressure. You will never know without trying or testing them. Personally i would have no qualms about trying any of them if they are new old stock.
Re: Spheres
Same here - I know it's often mentioned not to use old spheres but I don't actually know of anyone who has used them and found there to be a problem!Kevan wrote:Personally i would have no qualms about trying any of them if they are new old stock.
Re: Spheres
The only way to know is to either fit them to your car & you can do the bounce test or connect them upto a sphere tester which will let you know how much pressure they are holding & therefore their health. I'm guessing that fitting is probably the way forward for you you, unless you know of anyone localish that has a sphere tester?
Personally, when buying spheres (unless they are Westroen one's), i just won't buy old spheres, it reduces the risk of them being flat or not lasting as long, thats just me though.
Re: Spheres
Will fit them and see. Thing is they came with the car, obviously been in it for a while as most of them are still in taped up boxes (as they were delivered I suppose) and when opened they were all mouldy!
Re: Spheres
If they've never been fitted to a car, then there is a fairly good chance that they'll be fine, once fitted though, for some reason they can then lose pressure, i'm sure there was an explanation of why this might happen on this forum a while ago now.
Re: Spheres
you can check if the bladder is inflated but not how much pressure it contains by feeding a thin piece of the likes of locking wire into the hole in the center of the end of the sphere, if the wire only goes in by an inch or there abouts the bladder is inflated,
i have always thought they dont loose much if any pressure whilst on the shelf, or not being worked
smiffy1071
- pies are evil!
Re: Spheres
Quite honestly if they retain gas pressure, then they are ok to use no matter how old they are.
Good quality ones can have a shelf life of several decades, while cheap shitty ones can last a lot less.
Personally, I'd fit them, and if the car ISN'T rock solid, then they are ok to use.
Re: Spheres
As Smiffy says, fit them and see how they go, as youve got them already they will cost you nothing!
andycadabra
Re: Spheres
Just bought and fitted a pair of 'XL' reconditioned spheres from a motor spares shop who put them on gumtree at £10 each. There was no date mentioned on the sphere or the box , but one side appears to be noticeably harder than the other, so maybe is past its use by date.
I still haven't bled the system fully - I don't suppose this could be something that resolves itself when the hydraulic system settles down?
1992 BX 17TZD 130k
1987 BX 16TRS SORN
1987 BX 16TRS SORN
Re: Spheres
Are they identical spheres? If the outside dimensions are the same, check to see whether the valve is of the same design, if not, that might be the issue, or perhaps one is virtually flat? I'd alway's walk away from any re-conditioned spheres that aren't genuine citroen one's, they don't tend to be as good at holding their re-charge, unless you knew the history from a previous owner who you knew hadn't let them go too flat before they were re-charged & then it probably doesn't matter what make they are.
andycadabra
Re: Spheres
Funny you should mention that about the valve, Mulley, because despite the fact they both have the same part number, according to the sticker on them, the one that appears to be a dud has a 3 mm hole, whereas the good one has a 1 mm hole like the ones that I'd removed.
I have refitted one of the old ones, and will return the 'dud' for a refund.
I'm still curious as to why there is a difference, though..
1992 BX 17TZD 130k
1987 BX 16TRS SORN
1987 BX 16TRS SORN
JayW
- x 13
smiffy1071
- pies are evil!
Re: Spheres
That sounds more like an accumulator...
Re: Spheres
I think Smiffy might be onto something.
