Locked out of the BX, and the spare is in the car!! Help
themildbunch
Re: Locked out of the BX, and the spare is in the car!! Help
Post by themildbunch »
i now have the knowledge - thanks...
amazingly for bedminster, someone found the keys that were dropped right next to the car , then knocked on doors until they found someone in- left the keys with them who put a note with their mobile on the dashboard!
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
kiwi
Post by kiwi »
PM sent
And tip to anyone posting the way to do it on the forum!
Dont because you never know when some scotum will be reading it and target your BX.
1990 BX19 TZS Auto 06/11/1989
frog
x 12
Post by frog »
I would love to know how to do this. I locked my self out of my parts car a few weeks ago, that was interesting.
1989 Citroën BX 16v
1993 Citroën BX 16v project
kiwi wrote:PM sent
yes, which is why if I ever see said method of entry posted here it will be removed at once.
PM be our friend in this instance, althugh I have modified both cars now so that the easy method doesn't work anymore, and it's easy to do, although if I lock myself out of either car, I'd have to phone dad to come out with a spare set of keys.. Rather that than some scrote taking my car though
Doc can you pm me said method please
Birotor
Post by Birotor »
Of course you can get in! Stopping the rest doing it is harder! In the long run you can only go for a visible deterrent* OR make it take longer for the thief to break in OR make it require max damage OR max noise.
*I have just resurrected two period piece crook locks: one for the GS and one for the BX but if they really want it they'll get it.
glastofari
Post by glastofari »
Actually you guys can probably help... I need to shift a BX with no ignition key. Best way? I need the wheels to steer to use the A frame!
Use a centre punch to undo the steering lock bolts or disconnect the steering column on the bottom clamp to the rack?
glastofari
I'll investigate - many thanks! Just to cap it off the ignition barrel has just seized on the my GSA today as well. Hey hum!
