WANTED: Upper speedo cable
Matt H
Post by Matt H »
Needed for the new 16v, I know these are getting hard to find now, so any help muchly appreciated. Needed for the MoT!
Apparently the last one only lasted a couple of thousand miles, so I'm going to inspect - just to make sure it hasn't just popped off the speedo head... But fairly certain it has gone.
Re: WANTED: Upper speedo cable
The fact it's only lasted such a short length of time suggests something more is amiss...partially seized speedo? Don't know how likely that is though.
Check out the post Ian Fearn made about getting a custom one done. Sounded pretty successful to me.
JayW
x 13
Post by JayW »
Just a sidenote, a working speedo is not an MOT requirement.
PM sent
Post by RxBX »
JayW wrote:Just a sidenote, a working speedo is not an MOT requirement.
:? Check out THIS website !
Vehicle and Operator Services Agency (Issue Date 01 January 2012) wrote: This inspection applies to all vehicles first used on or after 01 October 1937. If the dial glass is cracked, it is not a Reason for Rejection, providing: there is no possibility of misreading the speedometer or there is no possibility fouling of the indicator needle or the cracked glass does not create a safety hazard.
A Tachograph is an acceptable alternative to a speedometer providing it satisfies the requirements of this inspection.
Select #3 'Inspection Manual for Classes 3, 4, 5 and 7 Vehicles' then (Browse), Section 6 (6.7 Speedometer) also HERE :wink:
I've known a cable snap due to a seized up odometer before now. I want to try to lube this on Timex at some point as the speedo wavers as each 100 is clocked, suggesting it may be winding the cable up.
1. Speedometer not fitted.
2. Speedometer incomplete, clearly inoperative.
How can they tell it is ''clearly inoperative'' without going for a test drive? I've never seen an examier test a speedo for operation or a VOSA examiner test a tachograph is registering.
Vantman
Post by Vantman »
[quote2
I've never seen an examier test a speedo for operation or a VOSA examiner test a tachograph is registering.[/quote]
Tachographs are,(or were) tested by a plug-in handheld instrument to make sure they register correctly and the VOSA man then signed the chart.
Brian.
2003 Saab 9-3.
Post by RxBX »
Defender110 wrote:Reason for Rejection
How can they tell it is ''clearly inoperative'' without going for a test drive? I've never seen an examiner test a speedo for operation or a VOSA examiner test a tachograph is registering.
Kevan,
The MOT tester, tests the speedometer operation on the 'Rolling Road' at the same time as they check out the brake performance :wink:
:lol:
You don't need a working speedo for the MOT.....unless you've got an extremely anal MOT tester!
Post by RxBX »
Kitch wrote:You don't need a working speedo for the MOT.....unless you've got an extremely anal MOT tester!
Therefore, it is part of the an MOT test/requirement (As from 1st January 2012) :roll:
Anyway back on topic, i have new one in a bag Matt!
Defender110 wrote:How can they tell it is ''clearly inoperative'' without going for a test drive?
On the brake rollers? I think it's one of the changes which came in this year, as it certainly wasn't tested several years back - I checked as the speedo on the 205 failed.
Without getting drawn into a debate, I've just looked on MOT.gov and it doesn't mention the speedo as a testable item.
