Oil leak TZS Auto
kiwi
Oil leak TZS Auto
Post by kiwi »
Not sure on the exact cause of this the location seems to show pooling of oil just below some green covered sensor type thing I am not sure of the purpose without checking. which is above the oil filter. Checked the breather pieps in that area and they are dry so likely candidates please. The one I can think of the most is Oil Filter blowing passed the gasket at pressure?
1990 BX19 TZS Auto 06/11/1989
Geoffrey Gould
Re: Oil leak TZS Auto
Post by Geoffrey Gould »
Hi oil pressure switch may be culprit. A leak from these is not unknown.
G.
1991 BX 1-7 td Auto.
NEVER WRONG.
kiwi
Post by kiwi »
That would be what that sensor is called, it got me confused on a quick look being a differant colour than on the other two petrol BXs.
You say not uncommon? Its the first I have come across in 20 plus years so once gain the BX are throwing out another learning curveball.
I changed the one on Timex because it wasn't working, but it looked much the same as those fitted to 2CV's, which are known for leaking.
Post by citronut »
not really hi oil pressure but just the oil pressure switch,
and yes they can leak,
i have seen this on 2CV's and G's
