Anyone thought of seeking a bit more go out of a n/a diesel?
oilybox
Re: Anyone thought of seeking a bit more go out of a n/a die
When changing my gearbox recently, due to the original 176,000mile one's diff self-destructing, I noticed that the exhaust manifold has 2 outlets!, 1 leads to the down pipe, as expected, the other is blanked off with a plate,... Can anyone tell me what the blanked-off exit is for?,.... Is it some sort of fitting flange for fitting a turbo to, if the manifold is used on both turbo and n/a engines?
mechanically-minded, technically-gifted,....self-confessed fix-it yourself fan....
barry badger
- x 10
Some of the na' s were fitted with a cannister, i think to collect soot under certain conditions? although someone may correct me on its purpose.
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
