MK 1 diesel airfilter pipe needed for Mollie
Post by Mothman »
Anyone got one of these, the air tube for a MK 1 Diesel. Runs from a hole in the bulkhead to the airfilter. Mollie's is knackered, most of the internal foam was in her airbox which has all now been cleaned and filter replaced.If this is made from unobtanium, any suggestions for a replacement that will work?
Thanks,
sdelasal
Re: MK 1 diesel airfilter pipe needed for Mollie
Post by sdelasal »
something like this may do the trick - ventilation hose aluminum not plastic though... Steve
Pretty sure there was one on Ebay a while back. There's not now, but it does suggest they are still out there.
Post by citronut »
here is price and part No. but its says NFP
95496464 INTAKE FILTER AIR HOSE 55.34 GBP 66.41 GBP 66.41 GBP
I bought for the GT about 4 years ago, for about £20, something you are bound to see at an autojumble.
My Cars: 1985 Citroen BX19 GT
2013 Nissan Leaf Acenta 24Kw
x 198
Post by saintjamesy89 »
The one on my GT is knackered too, they aren't very substantial eh?
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
Post by Mothman »
It seems that the foam inside the tube turns to dust and collects inside the air filter housing causing a right horrible mess inside. Ime kicking myself for not buying on feebay the bit of kit Ian mentioned but there you are, it might surface again sometime.
I suppose i could fit a K&N system, make the old goat go a bit faster!!
If you have access to a scrap bx, you can use the front heater vent pipe as a stop gap repair, o k. You will have to drill the holes using the old one as a pattern but it worked on mine
Or fit an induction kit?
Post by Mothman »
MULLEY wrote:Or fit an induction kit?
On an old MK 1?
Would it be ok?
I see no reason why it wouldn't work, just make sure the air filter cone is well away from heat & gets placed somewhere where the best cold airflow there is in the engine bay.
Yup. That'll be fine as an interim fix. Might make a little more induction noise but I doubt you'll notice over the XUD rattle.
You should be able to get some suitable tube, which you would then have to drill the holes in. Even if it was available from Citroen I'd consider doing that considering the price they wanted. May be worth looking at heater ducting tubes as a source - I don't think 2CV ones are long enough but think there are some longer ones available for air cooled VWs.
