Happy new year all!After trying to sell my gti last year with no joy I decided id keep it. When I went for a last run in it before tax and mot ran out. When changing gear the gear stick went all floppy and I ended up having the aa out. The guy packed it out and very delicatley I was able to drive the short distance home. The car has been like this since. Got it out the garage for the first time in 6 months and was able to put it in gear and drive it out although it feels very fragile. As regards to fixing the problem correctly does anyone have any idea of what parts are available gear linkage wise? It's a 19 gti if that makes any odds.
Thanks men.
Dave.
Gear linkage
ace_the_bass
JayW
- x 13
Re: Gear linkage
The 2 selector rods that most commonly fail are a ball & cup design (similar to rosejoints) and they have a plastic bushing inside the joint. Normally this bushing wears out and the cup becomes loose around the ball.
You'll see them if you look straight down behind your distributor toward the back of the gearbox.
These are easily replaceable with rods from another BX as all the XU's are the same. They simply pop off and pop back on. No adjustment should be required if they've come from a working unit.
Re: Gear linkage
i think these are the part No.'s and price's for the two link rods
LONG 241 DIAM 13 96049753 GEARSHIFT LINK 22.42 GBP 26.90 GBP 26.90 GBP
LONG 131 DIAM 10 96012463 SELECTION LINK 14.52 GBP 17.42 GBP 17.42 GBP
ace_the_bass
Re: Gear linkage
thanks chaps.
where can i order these from Malcolm? sounds like a pretty straightforward job if thats all it is.
Re: Gear linkage
I think you need a spare BX bud as i suspect these items are unavailable from Citroen.
- x 94
Re: Gear linkage
Some of the Peugeot uprated ones (Griffiths and the like) use a metal cup with retaining clip. I've adapted some 205 ones onto my BX.....they'll last a lifetime in theory.
ace_the_bass
Re: Gear linkage
i tried finding a spare bx when looking for something this time last year.......couldnt find one anywhere!
JayW
- x 13
Re: Gear linkage
Just stick a WANTED ad here. They're easily posted out.
Re: Gear linkage
just aim those numbers by citroen first, they will tell you if they are NFP,
im sure it did not state this when i checked the part No.'s
