Differences between the BE1 & BE3 Gearboxes
Since buying Timex, I've been keeping an eye open for a replacement gearbox, as 1st gear Synchro is dead, and the others can be beaten if you shift quickly. So far I've had no luck locating the correct box (BE1), so will either rebuild or have rebuilt the box in there this summer.
I was discussing this yesterday at Gaydon, and as a result aquired a scrap BE3 box toplay with (thanks Brian!) =D> . Before I end up tearing apart a gearbox I can't salvage anything from, does anyone know what the differences are between the 2 boxes. I assume the selectors are different because of Reverse being on opposite ends of the shift pattern, but were there other changes too?
The hope is to strip my BE1 box, fit all new bearings, then reassemble using (hopefully) the least worn parts of both boxes, with possibly some other new parts when necessary and available.
Re: Differences between the BE1 & BE3 Gearboxes
Post by citronut »
i know Rick Pembro is known more in dersh (2CV ) circles but i think he knows gearbox's in general link below
http://www.gearbox-guru.co.uk/" onclick="window.open(this.href);return false;
maybe give him a call as he's very good
Ah yes, I know Rick - I'll get in touch with him and see what he says.
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
You *may* find the synchros are swappable. In which I case I have spares. If you pm me your vin, I can check on Citroen service website for you or generate your own account
Thanks - I'll check the Vin No. tonight and get back to you
electrokid
Post by electrokid »
I was discussing this yesterday at Gaydon, and as a result aquired a scrap BE3 box to play with (thanks Brian!)
My pleasure :D
Quite a surreal conversation...
M I'm thinking of re-building the gearbox
B Oh I have a spare one of those in the back of the car
:lol:
