Is there a difference between a Mk 1 & a Mk 2 bonnet ?
Vince Pepper
My Cars: 1989 PH2 16v. White
Seat Leon FR. Whiter
Post by Vince Pepper »
I am after a new bonnet my 16v, there is one for sale on eBay listed as a 1988 BX14 in white, the question is will it fit my November 1989 registered car which is a Mk2, Also is Alpine White the only White in the BX range ?
Re: Is there a difference between a Mk 1 & a Mk 2 bonnet ?
I think a 14 might have the long nose bonnet, which is no good for a Valver.
I famously had a long nose bonnet on my valver , its not correct but didnt actually make any difference, cooling may be slightly better with a short nose one though
Bonnets are interchangeable from Mk1 to Mk2, short or long nosed, metal or GRP.
Post by RxBX »
Hi Vince,
I have a 'short nosed' White bonnet, manufactured from plastic/GRP which came off a TZD Turbo available !
PM sent :wink:
Post by Mothman »
If you also have the ducting etc that came off the underside of the TZD turbo's bonnet i would be very interested.
Post by RxBX »
Mothman wrote:If you also have the ducting etc that came off the underside of the TZD turbo's bonnet i would be very interested.
Don't fret Andy,
I'd already thought about your need/request if Vince just wants the bonnet :wink:
As you were initially earmarked for the whole bonnet/assy, but due to logistics/Courier costs it would have been too expensive IIRC !
I'll keep you posted !
Post by Mothman »
Cheers bud.
I wouldn't worry too much about the cooling issue, as most of the airflow into the engine bay is from below the bumper line.
Post by Mothman »
Isnt the ducting under the bonnet specifically for air for the turbo though? Cooling or otherwise?
Mothman wrote:Isnt the ducting under the bonnet specifically for air for the turbo though? Cooling or otherwise?
Yes mate, the TD have a special bonnet pad which is hollow that ducts air straight to the intercooler from a duct infront in the radiator.
